ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
JMU1998
Aug 22, 2017Luminary
I have to turn off then on wifi on Samsung s8+ many times daily issue still exists is Netgear Engineering working on the issue?
Disturbd1
Aug 22, 2017Star
Since it seems like not everyone new to the thread is reading:
1. The issue is a combination of the Galaxy S8/+ and the latest Orbi firmware.
2. For those on the US-unlocked variant, we are still waiting for Samsung to push the next OTA for our devices.
3. Some carriers such as Sprint and Verizon appear to have a security update for the S8/+ that has fixed this glitch (probably inadvertantly)
4. Netgear engineering is aware of this issue, and has acknowledged it previously in this thread. That said, they don't seem to be really doing anything to satisfy those of us hungry for a better answer than "please be patient".
5. Using the Guest wifi does work as a workaround, without any further modification needed. The downside being that you may have some issues with device isolation, some of which can be mitigated by checking the box to allow guest network attached devices to see other network devices
6. Resetting your router does absolutely nothing if you have the Galaxy S8 or S8+ that is running the firmware version that started the issue. A few people have reported otherwise, but if it works for one person it should work for everyone and it doesn't.
Please don't ask for updates without reading at least the more recent pages in this thread. Some of us are subscribing so we can see information that is helpful, and every reply sends an email notification that is pointless if you read through this thread.
- ameetpAug 23, 2017Guide
So, We are sitting here with a $350 wifi router that doenst work. Is netgear going to reinburse us?
This is getting very frustation for all of us. This needs to be resolved asap. We cant use our smart thing in our homes. (Hue, Sonos, etc.....)
- Dustin278Aug 23, 2017Apprentice
I heard that someone in another thread has a BETA firmware labled 2.0.0.62-debug in another thread - anyone else using this with any luck??
- littletechgirlAug 23, 2017Guide
I read everything before responding.
I'm on Verizon, the last update did not fix it for me. In fact, it seemed to make it worse!
I reset my router because at first I thought it might be an issue with that and not just the phone (before finding this thread). Doing that didn't hurt much. As we know though, that does not help.I will just keep using my phone on either 4G (unlimited data), or connected to my Xfinity router.
