ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
Luisfernan
Aug 28, 2017Guide
JMU1998 it doesn't matter if it's Verizon, Att or t mobile, it's the update Samsung did on July that it's not working with orbi. Just try the guest connection
Retired_Member
Aug 28, 2017
I've been using the guest SSID for a month, and while more stable than the primary, it experiences the same problems a few days after resetting the orbi to defaults.
- spinkickAug 28, 2017Apprentice
I've found the same. Guest network doesnt disconnect but its still kind of flakey. I'm going to try to get Verizon to send me a new phone with old firmware to test the other guys results.
- Retired_MemberAug 28, 2017
I have a hunch based on screwing with the situation for almost 45 days. The router is extremely stable for a few hours after a complete reset to factory defautls and reconfiguration. It gradually degrades over time following that...
Having reset the router numerous times since 1.11.x, that's been my experience anyway.
In fact, when the first .12 release for which I helped beta test, it was rock solid for several WEEKS UNTIL, I reset the Orbi due to installing new UPS's. Then it went flaky as all get out again, just like on 1.11.x.
Just FYI, I previously stated this began with 1.10, which was a typo, I meant 1.11.x.
- LuisfernanAug 28, 2017GuideRetired_Member that's on the guest connection or the normal one? So far on my case it's been working flawless on the guest connection. Normal connection drops like crazy
- LuisfernanAug 28, 2017GuideRetired_Member so far it's been working flawless on my s8. But I haven't reset my orbi so that might make a difference. I won't until it drops the Wi-Fi
