ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
JMU1998
Aug 29, 2017Luminary
Luisfernan returning phone is an option returning Orbi is not I got it when it came out. Not being able to reduce power on radios or turn off radios not being used is something Netgear removed which baffles me. I try not to be selfish and blast my router radio in all directions if I am not using them or have no need just contribute to the pollution/interference in your surroundings/neighbourhood/network environment.
spinkick
Aug 29, 2017Apprentice
The guest network does not use a different radio channel than your current network, it just broadcasts an additional SSID. So, you wont be contributing to any extra polution that you arent already causing. Until netgear fixes the firmware, nobody here can really help much more as we are just all users just trying to help each other out, and not representatives of netgear
- Dustin278Aug 29, 2017Apprentice
I can finally confirm that my Verizon S8 finally works without disconnect after todays Verizon update - It has been stable for the past 4 hours without a single drop in connection - I have walked all over my yard and through my home trying to get it to not respond.. I am also on the BETA firmware which had been working about the same up until the Verizon update this afternoon.
I have turned down the 2.4 intensity to 50% so that it stays connected to my 5 ghz more and I only have a couple 2.4 ghz devices
I even got full signal 100' into my backyard and speedtest'd with full DL and full UL speeds.
Here are my advanced settings:
- tnadkarniAug 29, 2017StarI can confirm that the Verizon update today fixed the issue for me. I am on .18 Orbi (not beta) and I didn't touch settings. Just disconnected from guest Network and connected to main. Been stable and fast for a few hours now. Will report back on thread if things change.
- climbingxAug 29, 2017TutorUpdated Verizon S8 today and working on main Network so far. Good luck everyone, let's hope this is the fix.
- spinkickAug 29, 2017Apprentice
I'm on the main network with the new verizon update, seems stable as well. Thank god!
- Retired_MemberAug 29, 2017Updated Verizon s8+ which according to the release notes contains no changes to wifi at all. Still periodic disconnects with all other devices previously mentioned.
- Disturbd1Aug 29, 2017Star
Well, after a very understanding coversation with a manager at Best Buy, they graciously agreed to allow me to return my Orbi and purchase something else. I've now had 2 Samsung Connect Home Pro hubs hooked up for roughly 3 hours, zero disconnects so far.
- lwestfallAug 29, 2017GuideMy S8+ is working rock-steady on the main non-Guest SSID now too after the Verizon update today!
- StkasmAug 30, 2017ApprenticeMy VZ S8 seems stable on main network after that update. I cannot reproduce the issue anymore. Hope it will stay this way.
I'll keep monitoring but it's good news. - JMU1998Aug 30, 2017Luminary
On my Samsung Galaxy s8+ today I went into "Settings" then selected "System Update" it said new update available I downloaded and installed it and so far no drops yet in wifi on phone, will monitor only been a few hrs since update. Have verizon phone.
- spinkickAug 30, 2017ApprenticeI've had no problems with the S8 since the update yesterday. I wonder what they fixed?
spinkick good question no idea what they fixed the release notes are kind-of vague nothing explicitly points to wireless or wifi fix, it is one of them magical "fixes/enhancements" that Firmware addresses but no one knows exactly what it is...for me it is working now so happy it was really frustrating drops in wifi constantly on the phone...fingers crossed!
