ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
RangerRick05
Sep 02, 2017Initiate
Updated my S8+ on T-Mobile, seems to have fixed the issues as well, so far, so good!
littletechgirl
Sep 02, 2017Guide
Same here. Been working great all day. Finally!!
- jlangnerSep 02, 2017Tutor
When did you get a update from T-Mobile. Still nothing here.
- Retired_MemberSep 02, 2017Worth continuing to note that no changes were made to S8/S8+ WIFI behavior or driver by Samsung on any carrier for the August updates. Any change you're seeing is merely placebo affect.
- spinkickSep 02, 2017ApprenticeLuckily that's an incorrect assumption. The update for August is fixing the s8 on all mesh style devices, check around the internet. It wasn't just An Orbi issue with the s8 and its absolutely solid now for most of us.
In fact, I had an rma s8 phone with an old firmware before the July update and it was stable too. Them July patch confirmed to wreck something, and then August patch its stable again.
Samsung often will make changes and not document them.
- ameetpSep 02, 2017GuideYes when did you get a tmobile update?
What part of country?- ElCidVisciousSep 03, 2017Aspirant
I have read every post in the long thread and am grateful for the guest Wi-Fi workaround suggestion. However, like others, I am still looking for the permanent resolution. I have a T-Mobile Galaxy S8+ with Andriod kernel version 4.4.16-11711626 dated July 14th, 2017. Security software versions
MDF v3.0 rel. 1,
WLAN v 1.0 rel. 1.
VPN v1.4 re. 8.1
ASKS v1.3_161228.
Orbi software version 1.4.0.18
It's encouraging to see that Verizon users have received an updated recently that appears to have resolved the problem. I would like to know if there is any way the Verizon users can correlate what was updated to we can speak intelligently with T-Mobile on what update we are also looking for.
Thank you
