ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
Stefanu
Sep 23, 2017Tutor
Same problem with connection here. And I already installed the V2 firmware from orbi
Turning WiFi off and on re-establishes the connection..
- DarrenMSep 25, 2017Sr. NETGEAR Moderator
Hello Stefanu
Who is your mobile provider?
DarrenM
- StefanuSep 25, 2017TutorTelenet.
But my previous router worked flawless.- Retired_MemberSep 25, 2017
The S8/S8+ have worked fine on all other wifi systems except the Orbi. You'll hear some misleading comments about "mesh", but the problems have only been verified on the Orbi and were improved, not by a S8/S8+ update, but rather by firmware updates from Netgear.
