ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
DarrenM
Sep 25, 2017Sr. NETGEAR Moderator
Hello Stefanu
Who is your mobile provider?
DarrenM
Stefanu
Sep 25, 2017Tutor
Telenet.
But my previous router worked flawless.
- AnonymousSep 25, 2017
The S8/S8+ have worked fine on all other wifi systems except the Orbi. You'll hear some misleading comments about "mesh", but the problems have only been verified on the Orbi and were improved, not by a S8/S8+ update, but rather by firmware updates from Netgear.
- thereverendSep 25, 2017GuideTxgunlover is incorrect. Mine stopped working immediately after I installed an update to my S8 in July and began working again immediately after I updated again a month later. I tested multiple Orbi firmware versions during this time. The disconnecting wifi only correlated to the S8 updates, not the Orbi updates. Several other people have reported this exact correlation. The initial reports for it breaking followed the carrier rollout in July/August and the resolution of the problem followed the next rollout, carrier by carrier. You can see the initial reports in TMobile's forums in July. At that time I didn't have an issue, but did when Sprint sent out that update shortly after. When VZ and Sprint sent out the next update, people on those carriers were fixed. TMobile customers still complained of disconnects, and had not received the update. I don't know how much clearer we can be here, txgunlover, but you seem really unconvinced and I can't understand why.
- AnonymousSep 25, 2017I'm simply talking about facts measured by external monitoring devices reported by me and others in this very thread. Opinions don't trump facts. As I said the 2.0.x branch has improved it, but statistically the August s8/s8+ patch had no effect.
