ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
Dustin278
Sep 25, 2017Apprentice
Retired_Member - how is it possible that you are the only one still having S8 problems with the Orbi. I after the Verizon August update mine had also been flawless. I think you are having other issues and may need to try another s8 on your network or get a new Orbi
Retired_Member
Sep 25, 2017- spinkickSep 25, 2017Apprentice
Others are t-mobile owners.
- ameetpSep 26, 2017Guide
Does anyone know when T-Mobile is sending this patch out?
This has gone way too long. None of the tips and tricks work.
Ok All T-Mobile subscribers, Lets get on the live chat with samsung (http://www.samsung.com/us/support/) and complain.
Obviously, they are not aware of this problem. See below.
- SorvenSep 27, 2017Initiate
Expect a firmware patch to go out over next day or so
- StefanuSep 27, 2017TutorFrom Samsung?
- jlangnerSep 29, 2017TutorGot TMobile update today. So far no disconnects. Switched from guest to normal... Yeah
- ElCidVisciousSep 29, 2017Aspirant
I am about to install the update but before I did I took a screenshot of the update screen. Like other comments I've read on other carriers updates, there do not appear to be any sort of reference to connectivity remediation, Wi-Fi or otherwise. See screenshot
- jlangnerSep 29, 2017Tutor6 hours of use and not one issue yet. This weekend will be the test. Hahaha
- StefanuSep 30, 2017TutorI have to get the update from Samsung. So I guess I still have to wait long time....
