ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M int...
gondek
Oct 23, 2018Initiate
This issue of the S8+ dropping from orbi wifi seems to have been re-introduced with the most recent phone update http://doc.samsungmobile.com/SM-G955F/TEL/doc.html a tell tale sign is the orbi app not being able to connect to the RB50 router. Need to raise this issue with Samsung, wondering if amyone having this problem again since S8 October 2018 update and their orbi? so frsutrating
MarcNett
Dec 30, 2018Tutor
Same type of problem with S9 and Note 8, seems working and next day no connexion.
- FURRYe38Dec 30, 2018Guru - Experienced User
What FW is currently loaded?
How was the FW updated on the Orbi? Auto update or manual FW file load?
Has a factory reset been performed then set up from scratch?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926Does any of this help?
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
- MarcNettDec 31, 2018Tutor
I have add picture with the configuration.
But it seems disabling BEAMFORMING and disabling Fast rooming improve the situation, This morning the 2 phones are still connected to the WIFI without error.
I continue to monitor
- FURRYe38Dec 31, 2018Guru - Experienced User
Thanks for letting us about those settings.
Something someone may want to contact Samsung about and let them know so they can also review this situation with there phones running on Orbi.
