acvitanov's avatar
acvitanov
Satellite won't connect - constant white pulse
I bought an Orbi with two satellites a week ago. Initially set it up, no issues and both satellites connected automatically. I then did the dreaded firmware update and now one of my satellites won't connect... Whenver it is powered on the top constantly pulses white. I have read over a decent amount of the forum, but haven't seen this specific expamle I think... I have reset the satellite, factory reset the router, gone through a complete reinstallation, but no go. I've tried going in through the orbi admin portal, but the satellite doesn't show up at all. Can anyone help me?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Are you able to connect directly to a satellite via Ethernet cable then try going to 192.168.1.250 and see if you can log into the unit and make sure its on the latest FW.
    DarrenM
    • acvitanov's avatar
      acvitanov
      Thanks for the suggestion, but unfortunately it does not connect to the satellite even through a wired connection. The laptop doesn't appear to establish any kind of connection with the unit at all.
