OrbiRocks's avatar
May 02, 2020
Security Tab missing
I've notices since putting the router in AP mode, I can't see the security tab. Is this normal?  Can I run Armor if the routers is in AP mode?
  • CrimpOn's avatar
    CrimpOn
    There are many things the Orbi no longer does when in Access Point mode, including Armor and Disney Circle.  That's what "Access Point" is rather  than "Router."  Since most people are better off with only one router, they have to decide which "router" they want the most and put the other device into "Non-router" mode.
    • OrbiRocks's avatar
      OrbiRocks
      Guide
      I only have the Orbi connected to my internet modem through the WAN port.  I had to put it in the AP mode to be able to get my direct tv box to connect.
