jrmurf
Jan 17, 2017Initiate
setting up an ORBI with a AT&T U-Verse Pace 5268AC
I have had my ORBI set up for a while but we are just noticing it is interferring with our download speeds
I have it wired to my Pace 5268AC, which I disabled the Wi-Fi and put the ORBI in AP Mode
my speeds flucuate from 1 to 3 Mbps, but when I unplug my ORBI from the Pace 5268AC my speed jumps to 6Mbps
What am I missing or what else can I do, it creates a very difficult Wi-Fi system to count on
Thanks for any help you can offer
- RonV42Luminary
If I am reading your post properly you plug the orbi in the AT&T Uverse 5268ac the speed drops and is unpredictable? I asssume you are using the "WAN" port on the Orbi and plugging it into port 1-4 on the 5268ac. Have you tried a different cable or a differnt port on the 5268ac? Usually pluggin a device into the uverse gateway shouldn't effect the speed of the device or perfomrnace unless there is a hardware issue such as cable or device.
What services do you subscribe to with U-verse in addtional to internet access? How are you measureing performance?
I turned off WiFi on the Pace modem and attached the Orbi to one of the ports. Then I went into the modem and put the Orbi into DMZ+ mode (bridge mode). No issues so far.
+1 juniormint88 I just configured the same setup with my Orbi system....put the AT&T gateway(5268ac) into passthrough mode using DMZ+ and didn't have an issues at all regarding a decrease in speed, etc......
- jrmurfInitiate
thank you all, I will try everything you suggested
I really appreciate the help!
