Butch1953
Jan 31, 2017Follower
Setting up Orbi
Just purchased at Best Buy - tried setting up yesterday evening. Followed setup and all was going good until went to web site to set up master unit. When it searched for my cable modem it couldn't find. Did all the usual swapping cables, powered down & reseting modem multiple times, powered down orbi etc. it never could find the cable modem. Modem has worked with a Lynksys E3000 wireless router for 2-3 years. Internet provider is Charter - cable type - modem is a Cisco DPC3208. About ready to take back to Best Buy but thought I would see if there is a fix?
- DarrenMSr. NETGEAR Moderator
Hello Butch1953
Any luck with the modem? There is no settings you should have to change on orbi should be able to plug your internet connection in the internet port of the orbi.
DarrenM
- Papaj1962Aspirant
I am having problem setting up my Orbi RBK50 with my Virgin Media Hub 3, everything starts ok, but then the orbi says it has not internet connection, by when I plug my PC directly in the Hub 3 which I have switch to a modem it works fine, is there a block somewhere between the Orbi and my Hub 3
- thedakApprentice
try to power cycle your cable modem. Often the cable modem will only accept one MAC address and stays bound to that until you power cycle it. The other approach is to clone the PC MAC address in the Orbi setup, but the former usually works fine.
