WVUANG's avatar
WVUANG
Follower
May 07, 2020
Single satellite firmware did not update
One of my satellites was turned off (thank you little one) when I updated the firmware recently.  Once the router rebooted, I noticed the one satellite was not connecting.  Once I realized it was powered off I checked and obviosully the firmware on the satellite was the older version.  I rebooted again but the update was not pushed to that satellite.
Is there a way to remedy this or do I have to wait for the next update?
1 Reply
  • FURRYe38's avatar
    First download the RBS FW version to your PC:
    https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1897955/highlight/true#M89460
    Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
