Yerky
Nov 24, 2018Tutor
Slow LAN Speed
I just recently installed the RBK50 for my home internet. When I plug directly into the router and run a speed test on my computer, I average between 300-500MBps. When I unplug the Orbi router from m...
Blanca_O
Nov 26, 2018NETGEAR Employee Retired
Hi Yerky
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
- Costa_LevineMar 22, 2019Aspirant
Same issue here, My ISP provides 1 Gbps down/up.
When connected directly (wired) to the ISP router I get ~800-1000 MbpsWhen connected to the Orbi's LAN I get ~500mbs download and 934mbps upload.
Same results in the internet speed in Orbi android app.Tried both: Router and AP modes. Same results.
*Firmware version: v2.2.1.210
Any updates about this slow LAN performance issue?
Thanks
- FURRYe38Mar 22, 2019Guru - Experienced User
Does your ISP use PPPoE or DHCP for there services to your modem?
There is more recent FW that you can try:
If you do, upate the Satellites directly to v32 first, then, update the RBR to v212 first, then apply v32. v212 is required before v32 can be applied on the RBR.
Thanks
I changed cables and tried to use another laptop and I started to get ~800-1000 Mbps on download.
Not sure what's going on with the internet speeds in the android app.
So, my issues resolved for now.
Thanks for the quick response FURRYe38
