TFlav's avatar
TFlav
Apprentice
May 01, 2021
Slow WIFI speeds on my rbr50 with ATT fiber
I resently got the BGW210 router from ATT as I read that it works best with my orbi rbr50. after getting everything set up, everyting was working great for a few days. Wired connection speed are coming in at 900+, while my wifi speed when sitting next to the router are around 300+. When i move just 15 feet away tho the speed drops down to 20 and lower. This has been an issue for about a week now and I'm not sure what could be causeing this. i know the more devices connected to my wifi will weaken it and I'm working on connecting as many as I can to a wire connection. This wasn"t as big of an issue with my old ATT router(5268AC).
  • FURRYe38's avatar
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    • TFlav's avatar
      TFlav
      Apprentice
      I've already configured my routers. I have both wifi's disabled and put the router in IP Passthrough on my ATT Router. I have my orbi router in AP mode. My satellite is no more then 30 feet from my orbi router. My orbi firmware is up to date.
      I followed these steps from this youtube video.
      https://www.youtube.com/watch?v=OZz6E8Xk_Hs
      If this is wrong can you guide me to a step by step guide on how to configure my setup?
  • FURRYe38's avatar
    What WiFi devices are you using to speed test with?
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
    • TFlav's avatar
      TFlav
      Apprentice
      FURRYe38 I use ookla speedtest app.
      I have no idea what channels I'm using or how to check them. I'm a noob when it comes this stuff. So if you could give me step by step instructions that will really help. I have no idea what beamforming, MIMO or WMM are. I really have no idea what you're asking me to check in the rest of the message you sent either. please be as specific as possible.
      • FURRYe38's avatar
        What devices are you using to speed test with?
        Use a wired PC connected to the RBR and a web browser to log into the RBRs web page at 192.168.1.1 or orbilogin.com.
        Check under Advanced Tab and you'll see what wireless channels the system is using.
        Follow the path under Advanced Tab/Wireless settings to check for the items mentioned.
        If you don't think you can check for these items, you may want to get someone to help you out on this, friend, nieghbor or family member.
