sclouser's avatar
sclouser
Solid Magenta ring on 1 of 2 Orbi RBR20 satellites
I have a 3 year old RBR20 with 2 satellites.  1 satellite has a solid magenta ring and won't sync, even when sitting next to the router.  The other is working fine.
The support troubleshooting guide provides this comment..."Your Orbi satellite has no backhaul connection to your Orbi router or it has no IP address", but doesn't provide any information to fix the problem.
Can this be fixed?
Thanks,
Steve
  • Thanks, that worked, but I had to do a reinstallation of the router and satellites in order to connect since I had originally made some setting changes to connect to my Verizon FIOS router.
    Thanks again...
    Steve Clouser
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello sclouser ,
    Welcome to the NETGEAR Community!
    I understand that you have a RBS20 that does not connect to the RBR20. Please connect to the satellite and verify that it has the same firmware as the router. If it is not the same firmware please update the firmware on your satellite to match the firmware on your router.
    Please navigate to the link below to verify the firmware and update your Orbi satellite:
    How do I check and manually update the firmware on my Orbi satellite? - NETGEAR Support
    For step-by-step instructions on how to manually update your RBK20 please navigate to the link below:
    https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
    Please keep me updated on the progress of this issue!
    Best,
    Kevin
    Community Team
    • sclouser's avatar
      sclouser
      Kevin,
      I ran the check and the firmware is up to date, but satellite #1 is not connecting…see below.
      What else can I do?
      Thanks,
      Steve
      Model Name
      Device Name
      Current Version
      Status
      Router
      RBR20
      RBR20
      V2.7.4.24
      No new firmware version available.
      Satellite
      RBS20
      Orbi Satellite-1
      V2.7.4.24
      Waiting for connection
      Satellite
      RBS20
      Orbi Satellite-2
      V2.7.4.24
      • KevinLiT's avatar
        KevinLiT
        NETGEAR Moderator
        Hello sclouser
        Thank you for providing that information!
        Please try a factory reset and then establish a connection between the router and satellite-1 before adding satellite-2. Rest assured that if you give your Orbi the SSID and login credentials that if had prior to the reset your devices should automatically detect the network and connect. There should be no additional configuration needed.  However, if there is, please give your RBR20 a few minutes to be fully connected to your end-user devices.
        Please navigate to the link below for instructions on how to successfully reset your Orbi Mesh system:
        https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
        Best,
        Kevin
        Community Team
