Gabbyrn's avatar
Gabbyrn
SONOS Compatability with Orbi
 Is Orbi compatable with the SONOS mesh network? I have an extensive SONOS system throughout my house (7000 sq ft). It works flawlessly and I have wondered why a mesh network for a LAN application has not been available before now. If Orbi works like my SONOS system and is compatable, it will be a real game changer.
  • Hey guys, so similar issue that I assume is related. Have latest firmware on my Orbi and satellite, everything runs great at about 180mps throughout my house. Sonos never drops out, except; whenever I play music using my surround sound setup (may also happen with tv sound but don't notice) the stereo pair drop out briefly every couple of minutes and then come back in, however playbar continues to play.
    Currently I have bridge wired into my router, Orbi on channel 1 for 2.4 and sonos on 11. Previously I had one of the stereo pair plugged into satellite as they are right next to each other instead of using the bridge but this was as bad if not worse.
    So any ideas what the issue may be? Would the satellite being next door to one of the stereo pair be an issue? (Haven't moved as have number of things on that shelf plugged into it).
    • MachineLearner's avatar
      MachineLearner
      Apprentice
      I believe Sonos recommends trying to keep some distance between wifi-connected Sonos units and the WAP to which they are connected.
    • st_shaw's avatar
      st_shaw
      Master
      Yes, it could be an issue.  Sonos uses 5 GHz for stereo pairing and Orbi uses 5 GHz for the backhaul.  I have seen Sonos interfere with the backhaul and have measured reduce throughput.  Try moving the Satelitte farther away from the Sonos stereo pair.
      • dleute's avatar
        dleute
        Apprentice
        I can tell you that Sonos was not working well for a while with it's internal sonosnet. It would drop several times a song. I just stopped using it for a few weeks. Eventually I switched it to use the Orbi network and things got much much better. I'm not sure how a stereo pair or surround sound would interact with that.
  • We have 4 Sonos units currently connected to our Orbi system and everything is working great.   Please note, however, that I use Cat 6 ethernet connections to the Sonos units, always have, just to eliminate any of the vagaries associated with wifi.  I have not tested them in wifi mode.  I connected a switch to one of the ethernet LAN ports on the Orbi router, and have cat6 runs to the Sonos units.   Same for other devices in home theater.
    We are getting great wifi coverage all over 3,000 sqaure feet on 2 levels with the 2 unit RBK50 (router at one end of first floor, satellite near middle of 2nd floor), and pretty good coverage in our basement as well.
    Please note some have had difficulties with Apple and Nest products.   We have Apple laptops connected wirelessly with no issues, but we keep OS X at current version, and there have been wifi issues with older versions of OS X with non-Airport routers.   Nest product forums show lots of wifi issues with many routers, especially older Nest products.   The more IoT products you have connected via wifi, the more research you will want to do about compatibility issues.
    Also, from what I can tell, some of the rants about issues with Orbi (on other discussions on forum) come from people who have connected the Orbi router to a cable co provided router.  Why they want to keep the cable co router I don't know, but I suspect many of these problems could be avoided by replacing the cable co modem/router combo with a simple cable modem, and using the Orbi as the router, as intended.  We are using an Arris SB 6190 as our cable modem, and it has been a champ.
    FYI, the Orbi system is replacing an Apple Airport Extreme router on first floor, which was connected via Cat 5 ethernet to a 2nd Apple Airport Extreme router (in "roaming mode" as recommended by Apple) on the 2nd floor.  This combo gave us excellent coverage on first floor, but weak wifi in a remote home office on 2nd floor.  The Orbi system gives us great wifi all over, despite the current lack of ethernet-connected backhaul for the satellite.  The dedicated backhaul channel seems to work very well for us.   We usuallly get close to our service level of 150mbs all over the house via wifi.
