JohnZxm's avatar
JohnZxm
SONOS One can't works in RBR20 with Wireless (only one RBR20,No satellite)
I have two sonos one device, It works connect to R6200 with wireless in before. As R6200 using so long time, So I buy new one ORBI RBR20 router replace r6200. After that time, My sonos can't work properly. The speed often just have 1M or 2M. and often lost connect , I need to rebuild the wifi connect then can found it. SONOS support engineer no ideal. Try so long time, They can't solved this problems.They reply me t is ORBI wireless network issue.
I using cable direct connect no problems.  Did anyone have the same problems?  Netgear support ,could you tell me how to solved this issue.
I also try seperate the 2.4G and 5G SSID, But not success.
  • I am sure one of the experts here will come along tomorrow with some suggestions for your wireless issues with your Sonos.  My Sonos is hardwired but just for your information it is working perfectly so far connected with about 15' of CAT6. It failed the first time I tried connecting it, but the 2nd time it worked. I did not have to do anything special for it.  I just just pushed the button on the Sonos and then let the Sonos App go through the connection steps it does automatically and it was good.
    • JohnZxm's avatar
      JohnZxm
      Thanks for your reply,Wired the SONOS to RBR20 is works,But I need via wireless connect,RBR20 just one eth port,I need connect to my NAS
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Try this, just temporarily disable the 5Ghz SSID broadcast while you set up SONOs on 2.4Ghz. Under Advanced Tab/Advanced Settings/Wireless Settings. Once setup, re-enable the 5Ghz SSID broadcast.
    • JohnZxm's avatar
      JohnZxm
      Thanks for your reply.
      I only one RBR20, Not have satellite.
      SONOS one nearly RBR20,
      2.4G channel has assign to channel 01.
      Already enabling Beamforming and MIMO
      I have try so many time about this with SONOS engineer, But not succes.
      I can not find the SONOS in ORBI router from yesterday,reboot router and SONOS no use. Sonos can not connect to RBR20.
    • JohnZxm's avatar
      JohnZxm
