rugbydman's avatar
rugbydman
SSID Naming
Hi. I just got my orbi rbk50. When setting up the system I tried to create the same ssid name as my old system which included a ‘
orbi setup says I can’t use this. So that means all my LIFX lightbulbs and ring doorbell have to be hard reset.
‘Why won’t it allow a ‘
surely this basic stuff
thanks for any help
  • FURRYe38's avatar
    This an Apostrophy? ( ' )
    Maybe some thing NG doesn't support on the Orbi system. i usually don't use specialized characters in SSID names. Maybe a ( - ) dash is all.
    You might ask NG support over phone weather they support that character or not.
      • FURRYe38's avatar
        Well for short term, you may have to. If this is something NG may fix, if they do, will take a while.
        You'll have to contact NG support about this.
