stevei1940's avatar
stevei1940
Steps to Install an additional RBR 50 to an existing RBR 50 system
I need to add an additional RBR 50 to an existing RBR 50 system for additional coverage.
What steps do I need to take to install it?
  • CrimpOn's avatar
    CrimpOn
    Mar 21, 2024
    Now that so many phones, tablets, laptops support WiFi6, replacing a WiFi5 system with WiFi6 (or even WiFi6E) is a common move.  The good news is that every major WiFi vendor sells capable products.  (The bad news is also that every major vendor has good products, so making a choice becomes more complicated.)
  • CrimpOn's avatar
    CrimpOn
    Netgear's Orbi products have two distinct models:
    • Router, such as RBR50
    • Satellite, such as RBS50
    Unlike some other companies, Netgear designed the Orbi line where there is one "router" and a variable number of "satellites".  There cannot be multiple routers.  Thus, Step 1 is purchase an RBS50.
    Once the satellite is on hand, plug it into power close to the router (so that it is easy to observe and manipulate both units).
    Then Step 2 is to use the Orbi 'app' or the Orbi web interface to Add a satellite.  (I much prefer the web interface).  See page 12 of the User Manual:
    https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
    Step 3 is to relocate the satellite to the desired location which is close enough to the router to get a "Good" connection (indicated by the ring light on the top turning Blue for 3 minutes) and far enough away to expand the WiFi coverage area as desired.
    • stevei1940's avatar
      stevei1940
      Thanks so much for this.  I mistakenly bought the wrong model. I bought the RBR 50.
      Can I use it as a satellite?
      • FURRYe38's avatar
        No, only as a router or in AP mode.
