Docgil's avatar
Docgil
Strange or not? Two LAN on same Orbi?
I have rbk50 and installed them correct. But I find it a bit strange that I can access my primary router using borth 192.168.0.1 and 192.168.1.1. Is this a faulty setup or is my router operating om both LAN levels? When entring my router using 1.1, I can see it the setup page that I have sat internal LAN to be 0.1. Should it be like this? I just think it is strange...2,4/5 thing?
  • Wow, I found this thread because I'm experiencing the same thing, although slightly different.  I configured my orbi to use 192.168.1.0/24 instead of the default 192.168.0.0 because I already had a bunch of static assignments in that range, so it was easier for me.  While troubleshooting an unrelated issue I discovered that I can browse to my router on either 192.168.2.1 or 192.168.1.1.  Weird.  I've combed through the screens and I can't find anything at all for 192.168.2...
    It should not behave this way.  Something is probably misconfigured.
    You refer to your "primary router".  Do you have other routers on your LAN.  If so, that could be causing your issue.
    On Orbi's LAN setup, make sure you are using the correct settings:
    • LAN IP address. 192.168.0.1
    • Subnet mask. 255.255.255.0
    • Docgil's avatar
      Docgil
      Hi
      I have one rbr50 and two rbs50 sat. The fiber modem is bridged. I do not have any other routers and I like to think I am pretty good in setting up a network. I am entering the same rbr50 using both ip-addresses. That is what I find so strange.
      • st_shaw's avatar
        st_shaw
        Master
        OK.  Did you check the Orbi GUI to see what the LAN IP and subnet mask settings are?
