superbovine
Oct 16, 2018Aspirant
switching requirements for ethernet backhaul
Hello,
I have 2 satellites (RBS50) and I like to setup an ethernet backhaul to RBR50.
When I connected the satellite directly to the same switch as RBR50, it establishes and ethernet connecti...
- Oct 17, 2018
What FW is currently loaded?
What is the Mfr and model# of the ethernet switch if one is in the configuration. Non managed switches are preferred and with out any GREEN ethernet features. If you have a Managed swtich, disable all IGMP protocols on these switches.https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1553749/highlight/true#M30673
https://community.netgear.com/t5/Orbi/Using-Router-Configured-as-Access-Point-Cannot-see-Satellites-in/m-p/1612052/highlight/true#M37974
https://community.netgear.com/t5/Orbi/Orbi-Ethernet-Backhaul-with-Managed-Switches/m-p/1613897#M38123Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Oct 17, 2018Guru - Experienced User
- superbovineOct 18, 2018Aspirant
I had green feature switch. I removed and replaced with a regular switch. Everything works fine now.
- FURRYe38Oct 19, 2018Guru - Experienced User
Thank you for letting us know about the difference in switches. Glad it's working now. Enjoy. :smileywink:
