OrbiPhilip's avatar
OrbiPhilip
Luminary
Mar 15, 2020
System logs
I would like to pull a history of the internet interface connection status.  Is there a comprehensive system log available for Orbi?   The one on the Advanced - > Administration -> Logs page is just slightly less than useless.
  • Every time the router reboots, the logs get cleared.  So that is frustrating.
    I have noticed at http://orbilogin.net/debug.htm you can set some log options.  It almost seems to suggest that if you insert a USB memory stick it may save them off.  You may need to try differnt formats (FAT32, EXT2/3/4, etc) until it is recognized by the Orbi.  You may need to find some free disk utilities.
    Something to try.  Other folks can probably provide additional guidance.
    • CrimpOn's avatar
      CrimpOn
      I have used a USB stick to capture LAN/WAN traffic many times.  However, only the LAN and WAN traffic captures appear on the USB stick.  The "debug" information remains in memory.
      • OrbiPhilip's avatar
        OrbiPhilip
        Luminary
        It seems that Netgear only developed enough of each feature to list it on the box as being present.  I cannot think of a single one where I thought "Wow, this is really well done".
