bentwookie
Mar 19, 2018Guide
Tell the Wire Cutter to reconsider their recommendation of the Orbi
I bought the Orbi 3 pack at Costco on the recommendation of the Wire Cutter. It might have been a fine product then, but it's garbage now (and has been for months). I've reached out to the review site via their Contact-Us link to ask them to reconsider their recommendation. Given what so many of us are experiencing, I encourage you all to do the same.
https://thewirecutter.com/contact-us/
- djc6Luminary
I bought my RBK53 three pack at Costco in November 2016, its been a pleasure to use for almost 1.5 years.
I recommended it to two of my friends, they are happy with it as well. While there are a lot of complaints on this forum, I think there are many more it works great for.
- Anonymous
same here....bought mine from Costco last Nov 2017. Other than a few disconnects, it works. I'm able to get to the Internet.
That it annecdotaly works for some people (and apparently only some of the time at that) doesn't make it a product worthy of their highest recomendation.
Products worthy of recomendation don't have their firmware downgraded for months on end. Netgear didn't do that just for kicks. People are having real problems.
In its current state, the Orbi is not worth recommending to anyone.
Mines been working great as well, however new to the Orbi scene. Been online for two months solid. It's not always a HW or FW issue. There are other factors that can cause routers and wifi not to work well, theres environment, configuration and user set up that can impact how well all this works. ALL FW versions are still available from NG support. NG just pulled the recent one from being automatically upgraded. It's still available for use. Users and NG support need to troubleshoot where issue are present to really find out where the real problem is, where it be HW or otherwise.
The article and recommendation is valid.
For the third time: The problem was widespread and serious enough for the company to pull its own firmware.
Why should the Wire Cutter put their own reputation on the line to recommend a product with known issues like this?
I don't understand the zeal to defend Netgear's poor efforts here. How do I get more customers like you guys?
Again, NG only pulled it from being auto updated. It's still available and some have had good experiences with that version of FW.
Again, it's not always a HW or FW issue. Again, the problems seen can be caused by other factors.
Some of us are here to help find out where the real problems are, answer questions, provide help for those asking and help NG improve where issues are really at. Nothing wrong with this.
Besides, wirecutter isn't the only one with reviews about the Orbi system:
https://www.smallnetbuilder.com/wireless/wireless-reviews/33028-netgear-orbi-reviewed
This site tends to offer more testing results and more accurate reviews of routers and wifi.
