astake's avatar
astake
Temporary disable all 5GHz channels of Orbi router.
I need to disable the 5GHz channels in order to add new smart home devices which support 2.4GHz only. I have no clue to separate the SSID of 5GHz & 2.4GHz. I found the way to disable 5GHz temporary from the post "Temporaily Disable 5g network on Orbi with mac terminal commands" by the following telnet command:
seconds=600; x=0; while [ $x -lt $seconds ]; do ip link set down dev $(config get wl5g_NORMAL_AP); x=$(( x + 1 )); echo "down $x"; sleep 1; done
However, only one 5GHz channel was disabled but the other is still there. Any can help what is the comman to disable both 5GHz channels. Or it had better to have the command set.
  • It’s the same command, but you need to execute it on the Satellite. I guess that you only done this for the Router.
    • tomschmidt's avatar
      tomschmidt
      Virtuoso
      Try this method which works for most IoT devices that require your smart phone to also be on the 2.4GHz frequency to configure their WiFi.
      1. Launch a web browser from a computer or mobile device that is connected to the Orbi network.
      2. Enter orbilogin.com or 192.168.1.1 (IP address of your router's LAN port).
      3. The login window opens, enter username "admin" and the password that you configured for your router.
      4. Click Advanced tab > Advanced Setup > Wireless Settings.
      5. Uncheck the box "Broadcast SSID" for the 5GHz frequency and click Apply to save the settings.
      6. Confirm that your smartphone is connected to the 2.4GHz frequency. If it is still connected to the 5GHz frequency, then "Forget" the WiFi network for your SSID, then reconnect to it and enter your SSID password. Now your smartphone should be on the 2.4GHz frequency.
      7. Try connecting your IoT device to the Orbi network per its setup instructions.
      8. If it works, re-enable the broadcast SSID option for the 5GHz frequency.
      9. On your smartphone, turn WiFi off and back on again and it should reconnect to the strongest signal.
      10. If your smartphone did not reconnect to the 5GHz frequency, then "Forget" the WiFi network again for your SSID, then reconnect to it and enter your SSID password.
      • astake's avatar
        astake
        Thanks but no luck. I tried to forget then turn the WiFi off or turn the phone off then back  again. My I phone always connected back to 5GHz. I disabled 5GHz SSID broadcast and set 5GHz power to 25%.
    • astake's avatar
      astake
      I did not turn on the satellite. One of the 5GHz shut down but the other still there.
      • ekhalil's avatar
        ekhalil
        Master
        It's omly one fronthaul network broadcasted from the router. What other network do you see? Is it the "hidden" backhaul network?
  • FURRYe38's avatar
    Netgear provides a simple mechanism to accomplish this:
    Log into the Orbi web interface (http://orbilogin.net)
    Navigate to the Advanced Tab, Advanced Settings, Wireless Settings
    Uncheck the box, "Broadcast SSID on 5G"
    Click "Apply"
    All devices that are currently connected to the Orbi will remain connected.
    On the smartphone, go to wireless settings and "forget" the Orbi SSID
    Search for available WiFi networks. Select the Orbi WiFi. Enter the password. and connect.
    If you are curious about whether the smartphone is actually connected at 2.4G, you have to wait a few minutes, because the "Attached Devices" display takes a while to update.
    Open the app and set up the 2.4G device.
    Once the device is connected and working as it should, reverse the steps.
    Check the "Broadcast" box and click "Apply"
    "Forget" the Orbi WiFi. Search. Enter password. Connect.
