darreln's avatar
darreln
The case of the disappearing Sonos system...
I have a Sonos sound system, with 4 speakers and 1 Bridge (for HT). I have the RBR50 router with a satellite, and a RBW30 plug-in AP. Everything has been working flawlessly until recently. Starting a few weeks ago, when pulling up the Sonos app on my phone, it searched for and suddnely could not find any of my set up rooms or speakers. This has happened at least 3 times now, and most recently just now. Testing connectivity with other devices shows that the Internet is up and available, so this issue seems to be isolated to the Sonos system & Orbi network.
I was unable to get the sonos rooms/speakers to show back up, so I rebooted the RBR50 router and waited about 5 minutes. Then I checked the Sonos app again. Slowly, one by one the set-up rooms & speakers started showing up again, and I was able to play music again.
Anyone have any insight or tips on what's going on here? It is my assumption that this is an Orbi system problem, since rebooting the router appears to fix the issue. Any help on further troubleshooting or analysis would be greatly appreciated.
Current Firmwares:
Router & Satellite: V2.2.1.210
Satellite Roamer: V2.2.1.204
  • FURRYe38's avatar
    How are the sonos connected? Wirelessly? Wired connections do anything different?
    Lots of issues with Sonos devices and routers. Besure they aren't broadcasting there own wifi as well...
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    What WPA security modes are you using? Try WPA2 and AES only and not Auto.
    ry disabling the following and see:
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
    Try setting a IP address reservation for the Sonos devices...
    • darreln's avatar
      darreln
      thanks for your reply. Here's my responses.
      -all wirelessly. I don't have any wired connections nearby the speakers
      -not sure what that means, do you mean that sonos speakers create their own wifi network? Don't see an option in their app for that..
      -2,880 modern build, kills wifi dead. Hence the satellite & the plug-in satellite. been working just fine for a long time...
      -router is in the wiring closet, satellite is upstairs and does show valid connection. plug-in is downstairs within 30 feet i'd say
      -channel 3 for 2.4 (which I believe sonos uses).
      -showing around 10-12...
      -WPA2 is set
      - that's a lot of settings to mess with, I'll take a look at those :)
