successhawk
Mar 31, 2020Follower
This NETGEAR device is already registered with another account
I have the exact same problem, and I see there was no resolution.
I never tried to enable remote connection until now (as far as I remember). I bought this new a while back.
v2.4.21.938
Firmware v2.5.1.8
I get the following error in the Orbi Android app when connected to my Orbi Wifi (in Router mode connected to ATT gateway) and I go to Menu -> Settings -> Remote Management -> Enable Remote Management
"Something went wrong"
"This NETGEAR device is already registered with another account"
"Note: If you factory reset your router, you must re-enable remote management"
Where did you get your system from?
You'll need to make contact with NG support to help you with registration problems.
- Blanca_ONETGEAR Employee Retired
Hi successhawk
Welcome to NETGEAR Community!
Please send me a private message with the following information by clicking on this link :
Name
Email address
Device Serial number
Blanca
Community Team
