LoboTommy
Jan 04, 2019Luminary
Trouble in stability Orbi rbk40
So, I have some issues.
My setup are one rbr20 and three rbs20. They are wireless backhauled. Internet is provided by altobox Norway, fibre optic network. Modem is bridged, leaving the rbr20 as the main network router. All satelites and router are up to date firmware.
Sometime last night, all the orbis went down flashing all colours. After tons of reboots, sync button clicks, setups and setups I managede in the end to have them all talking again, but only one links up good. The two others link "poor". According to the app, they are offline. According to the dashboardinterface they are online, but poor quality.
I need help, to get them running smooth again. Everything was fine for about a week, with no issues.
Please ask what information you want to help me troubleshoot.
- Finnaly, the solution!
After talking alot with support, they guided me to the newest manually update of the firmware
https://kb.netgear.com/000060607/RBR20-RBS20-Firmware-Version-2-3-0-28
Updated, and finally stability!
- ekhalilMaster
- What is the approximate distance between the Router and Satellites?
- What type of wired devices do you have connected to Orbi? Any speakers (e.g. Sonos)?
- Please toggle the Daisy Chain setting that you find in the GUI under >> ADVANCED >> Advanced Setp >> Wireless Setup
- LoboTommyLuminaryDistance beteeen rouyer and satelites varies. About 10-15 meters (i live in a metric country). Lot of strange walls to signal through though.
Two wired units connected. A PS4 pro wired directly to the router, and a stationary computer wired to one satellite. Rest of the house is wireless.
Daisy Chain has been toggled on and off numerous times, without any difference.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using? Try WPA2 and AES only.Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Advanced Tab/Advanced Settings/Wireless Settings
Please ask what information you want to help me troubleshoot.- LoboTommyLuminaryI'm so bad with square feet. But I used an online converter.... 100 Square Meters =
1,076.3910 Square Feet.
There is at least 15 meters inbetween.
Channel 11 in 2.4ghz is set, cuz it was unused by any neighbours (used Wi-Fi analyzer)
The 5ghz is also set to a free channel, though I can't recall witch atm.
All these settings are toggled on an off in various combinations with little to no effect.
In the end, I factory reset the router and satelites, and set it up from scratch. Now it's stable again- ekhalilMasterGreat that things are stable now. Hope it will stay like that.
