spizzi
Jun 26, 2017Tutor
Trouble Setting Up Orbi VPN on Mac OSX
Hello - I tried searching for the answer but none of the search results seemed relevant. I must be missing a step somewhere. Here is what I did: Orbi WiFi has the basic installation complete a...
- May 06, 2018
I found the answer. For the time being, I left my modem/router as the DHCP server, identified the internal IP address of the RBR50 assigned by my modem/router and put that internal IP address in the DMZ. I also left my Orbi as a router too, not an Access Point. Tested on an external network connection and it worked.
DarrenM
Jul 06, 2017Sr. NETGEAR Moderator
Hello Spizzi
Here are out articles on how to set up the vpn on IOS and mac.
https://kb.netgear.com/29826/How-do-I-use-VPN-on-my-Nighthawk-router-with-my-iOS-device
https://kb.netgear.com/25389/Enabling-VPN-service-on-a-Nighthawk-router-using-a-MAC-OS-computer
DarrenM
spizzi
Jul 21, 2017Tutor
I appreciate you sending me these but I had already gone through them before I submitted my question. None of these helped. There must be something I am missing in the steps. Maybe my original post was not clear? Basically, my connection times out from both a laptop and from my iOS phone.
Do I need to set up a Static Route in the Advanced Setup? Do I need to do Port Forwarding/Triggering in the Advanced Setup? I already have Dynamic DNS set up and running on the Orbi - maybe something needs to be tweaked here? Do I need to do something in my Cable Modem?
- SallyBelgiumNov 16, 2017Aspirant
I tried the installation scripts as well without any success... my ip address stays the same :-(
Anyone any ideas??
