spizzi
Jun 26, 2017Tutor
Trouble Setting Up Orbi VPN on Mac OSX
Hello - I tried searching for the answer but none of the search results seemed relevant. I must be missing a step somewhere. Here is what I did: Orbi WiFi has the basic installation complete a...
- May 06, 2018
I found the answer. For the time being, I left my modem/router as the DHCP server, identified the internal IP address of the RBR50 assigned by my modem/router and put that internal IP address in the DMZ. I also left my Orbi as a router too, not an Access Point. Tested on an external network connection and it worked.
rhherrera88
Dec 07, 2017Aspirant
Spizzi,
This is a year late, but I actually used your forum and it helped. Everything you did worked just fine. Test your VPN by connecting from another network, such as a phone hot spot. Then connect to your Orbi via the internal address. If this works, be rest assured that you are on your own network via VPN.
Thanks
Ramon
