bardaravine
Sep 30, 2017Aspirant
Tunnelblick VPN Client on a Mac does not change the public IP
Public IP address not changing when I log into the VPN. I would like to browse the internet from this VPN, but tunnelblick client isn't routing all my internet traffic through my house. Running Mac OS X 10.12.6. Log file from Tunnelblick below.
What am I doing wrong??
Tunnelblick: OS X 10.12.6; Tunnelblick 3.7.3beta03 (build 4870); prior version 3.7.2a (build 4851)
2017-09-30 18:21:53 *Tunnelblick: Attempting connection with client2; Set nameserver = 769; monitoring connection
2017-09-30 18:21:53 *Tunnelblick: openvpnstart start client2.tblk 1337 769 0 3 0 1065330 -ptADGNWradsgnw 2.3.18-openssl-1.0.2l
2017-09-30 18:21:53 *Tunnelblick: openvpnstart log:
Loading tap-signed.kext
OpenVPN started successfully. Command used to start OpenVPN (one argument per displayed line):
/Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.3.18-openssl-1.0.2l/openvpn
--daemon
--log
/Library/Application Support/Tunnelblick/Logs/-SLibrary-SApplication Support-STunnelblick-SShared-Sclient2.tblk-SContents-SResources-Sconfig.ovpn.769_0_3_0_1065330.1337.openvpn.log
--cd
/Library/Application Support/Tunnelblick/Shared/client2.tblk/Contents/Resources
--setenv
IV_GUI_VER
"net.tunnelblick.tunnelblick 4870 3.7.3beta03 (build 4870)"
--verb
3
--config
/Library/Application Support/Tunnelblick/Shared/client2.tblk/Contents/Resources/config.ovpn
--verb
3
--cd
--management
127.0.0.1
1337
--management-query-passwords
--management-hold
--script-security
2
--up
/Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -9 -a -d -f -m -w -ptADGNWradsgnw
--down
/Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -9 -a -d -f -m -w -ptADGNWradsgnw
--route-pre-down
/Applications/Tunnelblick.app/Contents/Resources/client.route-pre-down.tunnelblick.sh -9 -a -d -f -m -w -ptADGNWradsgnw
2017-09-30 18:21:53 *Tunnelblick: Established communication with OpenVPN
2017-09-30 18:21:53 OpenVPN 2.3.18 x86_64-apple-darwin [SSL (OpenSSL)] [LZO] [PKCS11] [MH] [IPv6] built on Sep 26 2017
2017-09-30 18:21:53 library versions: OpenSSL 1.0.2l 25 May 2017, LZO 2.10
2017-09-30 18:21:53 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:1337
2017-09-30 18:21:53 Need hold release from management interface, waiting...
2017-09-30 18:21:53 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:1337
2017-09-30 18:21:53 MANAGEMENT: CMD 'pid'
2017-09-30 18:21:53 MANAGEMENT: CMD 'state on'
2017-09-30 18:21:53 MANAGEMENT: CMD 'state'
2017-09-30 18:21:53 MANAGEMENT: CMD 'bytecount 1'
2017-09-30 18:21:53 MANAGEMENT: CMD 'hold release'
2017-09-30 18:21:53 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
2017-09-30 18:21:53 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2017-09-30 18:21:53 Socket Buffers: R=[196724->196724] S=[9216->9216]
2017-09-30 18:21:53 MANAGEMENT: >STATE:1506810113,RESOLVE,,,
2017-09-30 18:21:53 UDPv4 link local: [undef]
2017-09-30 18:21:53 UDPv4 link remote: [AF_INET]24.126.34.98:12974
2017-09-30 18:21:53 MANAGEMENT: >STATE:1506810113,WAIT,,,
2017-09-30 18:21:53 MANAGEMENT: >STATE:1506810113,AUTH,,,
2017-09-30 18:21:53 TLS: Initial packet from [AF_INET]24.126.34.98:12974, sid=0f8b24aa 1b1e4076
2017-09-30 18:21:53 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear, [email protected]
2017-09-30 18:21:53 VERIFY OK: depth=0, C=TW, ST=TW, O=netgear, OU=netgear, CN=netgear, [email protected]
2017-09-30 18:21:53 *Tunnelblick: openvpnstart starting OpenVPN
2017-09-30 18:21:54 Data Channel Encrypt: Cipher 'AES-128-CBC' initialized with 128 bit key
2017-09-30 18:21:54 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2017-09-30 18:21:54 Data Channel Decrypt: Cipher 'AES-128-CBC' initialized with 128 bit key
2017-09-30 18:21:54 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2017-09-30 18:21:54 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
2017-09-30 18:21:54 [netgear] Peer Connection Initiated with [AF_INET]24.126.34.98:12974
2017-09-30 18:21:55 MANAGEMENT: >STATE:1506810115,GET_CONFIG,,,
2017-09-30 18:21:56 SENT CONTROL [netgear]: 'PUSH_REQUEST' (status=1)
2017-09-30 18:22:01 SENT CONTROL [netgear]: 'PUSH_REQUEST' (status=1)
2017-09-30 18:22:06 SENT CONTROL [netgear]: 'PUSH_REQUEST' (status=1)
2017-09-30 18:22:07 PUSH: Received control message: 'PUSH_REPLY,route 192.168.1.1 255.255.255.0 192.168.1.1,route-gateway dhcp,ping 10,ping-restart 120'
2017-09-30 18:22:07 OPTIONS IMPORT: timers and/or timeouts modified
2017-09-30 18:22:07 OPTIONS IMPORT: route options modified
2017-09-30 18:22:07 OPTIONS IMPORT: route-related options modified
2017-09-30 18:22:07 TUN/TAP device /dev/tap0 opened
2017-09-30 18:22:07 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -9 -a -d -f -m -w -ptADGNWradsgnw tap0 1500 1590 init
Start of output from client.up.tunnelblick.sh
Did 'ipconfig set "tap0" DHCP'
Configuring tap DNS via DHCP asynchronously
End of output from client.up.tunnelblick.sh
2017-09-30 18:22:09 MANAGEMENT: >STATE:1506810129,ADD_ROUTES,,,
2017-09-30 18:22:09 /sbin/route add -net 192.168.1.1 192.168.1.1 255.255.255.0
route: writing to routing socket: Can't assign requested address
add net 192.168.1.1: gateway 192.168.1.1: Can't assign requested address
2017-09-30 18:22:09 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
2017-09-30 18:22:09 Initialization Sequence Completed
2017-09-30 18:22:09 MANAGEMENT: >STATE:1506810129,CONNECTED,SUCCESS,,24.126.34.98
2017-09-30 18:22:09 *Tunnelblick: No 'connected.sh' script to execute
2017-09-30 18:22:10 Extracted DHCP router address: 192.168.1.1
Sleeping for 0 seconds to wait for DHCP to finish setup.
Sleeping for 1 seconds to wait for DHCP to finish setup.
Retrieved from DHCP/BOOTP packet: name server(s) [ 192.168.1.1 ], search domain(s) [ ] and SMB server(s) [ ] and using default domain name [ openvpn ]
Not aggregating ServerAddresses because running on OS X 10.6 or higher
Setting search domains to 'openvpn' because running under OS X 10.6 or higher and the search domains were not set manually (or are allowed to be changed) and 'Prepend domain name to search domains' was not selected
Saved the DNS and SMB configurations so they can be restored
Changed DNS ServerAddresses setting from '192.168.0.1' to '192.168.1.1'
Changed DNS SearchDomains setting from '' to 'openvpn'
Changed DNS DomainName setting from 'hsd1.dc.comcast.net.' to 'openvpn'
Did not change SMB NetBIOSName setting of ''
Did not change SMB Workgroup setting of ''
Did not change SMB WINSAddresses setting of ''
DNS servers '192.168.1.1' will be used for DNS queries when the VPN is active
NOTE: The DNS servers do not include any free public DNS servers known to Tunnelblick. This may cause DNS queries to fail or be intercepted or falsified even if they are directed through the VPN. Specify only known public DNS servers or DNS servers located on the VPN network to avoid such problems.
Flushed the DNS cache via dscacheutil
/usr/sbin/discoveryutil not present. Not flushing the DNS cache via discoveryutil
Notified mDNSResponder that the DNS cache was flushed
Setting up to monitor system configuration with process-network-changes
2017-09-30 18:22:14 *Tunnelblick: This computer's apparent public IP address (73.200.235.104) was unchanged after the connection was made
2017-09-30 18:22:19 *Tunnelblick process-network-changes: A system configuration change was ignored
- DexterJBNETGEAR Moderator
Hi bardaravine,
1. What is the firmware version of your router?
2. What version of Tunnelblick do you have installed?
3. Do you have the option set to "All sites on the Internet & Home Network", "Home Network only", or "Auto"?
Dexter
Community Team
Hi bardaravine,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- bardaravineAspirant
I've since returned the router and exchanged it for an Asus. Current router is working like a champ. Who knows what I did wrong.
Thanks for reaching out.
Hi RThomas1975,
1. What is the model number and firmware version of your router?
2. Does the Internet work when you are connected?
3. What version of Tunnelblick are you using?
4. Does the issue persist when using another device (PC or Mac, iOS and Android if supported)?
Dexter
Community Team
- RThomas1975Aspirant
1. What is the model number and firmware version of your router? RBR50, Firmware V2.1.2.18
2. Does the Internet work when you are connected? Yes
3. What version of Tunnelblick are you using? 3.7.4b (build 4921)
4. Does the issue persist when using another device (PC or Mac, iOS and Android if supported)? Works fine on iOS... the problem is on the Mac.
- DJ_CoolInitiate
I have had this and was able to fix it by changing from a tun to tap connection.
- To do this, in Tunnelblick go to VPN Details, Edit OpenVPN configuration file. It's found in the bottom left corner after hitting the gear icon.
- Change your line "dev tun" to "dev tap" and make sure you update the port as your VPN server (the router) likely uses a different port for tap vs. tun. This will change your IP but in my experience doesn't let me network with the other computers on the network so I have 2 configurations, one if I want to connect to the local network computers and leave my IP alone (tun) and one if I want to route all my browsing through home network but not connect to local machines (tap).
