af8
Jan 07, 2018Guide
UK Orbi broadcasting with a DE country code
My Orbi (RBK50-100UKS) purchased in the UK, and always used in the UK, seems to be broadcasting with a country code DE rather than GB. Apparently this may be causing problems for another local netwo...
af8
Jan 09, 2018Guide
Having researched this a bit on this forum and others, I don't appear to be the 1st instance of the issue but there don't seem to be any solutions. Has anyone seen any potential solutions?
Cheers
- wwinter86Jan 26, 2018Aspirant
I use to have an Apple Time Capsule until it stopped working and everything showed a country code of GB/UK which is right, but since getting a Orbi my Macbook Pro always has a country code of DE. Did anyone find a solution?
- af8Jan 29, 2018Guide
Netgear support have been looking at it and please find below some info:
There isn't an option to select per country, it is set that once Europe is selected as a region it selects Germany to represent it. This doesn’t present a problem because UK, Germany and other countries in the European Union follow the same RF regulatory standard. Othere people locally connecting to another network should not be affected because of the WiFi country code specially if your router did not select those channels as well.
I have gone back to them with the documented issues that others have had with apple devices in particular as the above is a little less than a solution.
