UP4278's avatar
UP4278
Unable to access the admin page after firmware update
Orbi RBR20 - After applying the most recent version of the firmware (2.6.1.36), my admin credential doesn't work. I went through input the router serial#. Then it asked input for 2 security questions, it doesn't like my answers. Unable to proceed..
What options do I have to reset the admin credentials and reset the security questions? (without factory reset).
Thanks much
  • FURRYe38's avatar
    Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
  • It's hearing stories like this that make me nervous about updating firmware.
    Are you sure you entered the correct admin username/password?
    • UP4278's avatar
      UP4278
      100% certain. I used the correct admin password. (not entirely sure about the security questions).
      Now it is a mess I needed to reinstall the entire thing. :(
      • FURRYe38's avatar
        Let us know how the reset goes. After setting up from scratch be sure to save off a backup of the configuration to file for safe keeping. Saves time if a reset is needed.
