finny23j's avatar
finny23j
Unable to Map drives after setting up Orbi RBR50 mesh network
I have updated my Netgear router to the Orbi RBR50 Mesh network. Since then I have not been able to map drives to computers around the house. Windows says that it is able to connect but the device is not responding. This was working with my old Netgear router and now it is not with the new.
Is there any settings on the ORBI I need to make to allow this to happen?
Kurt
  • Glad you found the problem and fixed it.
    Please mark your thread as solved so others will know for future referece.
    Enjoy. :smileywink:
  • FURRYe38's avatar
    Ensure all devices are connected to the Orbi system.
    Ensure your not using any static IP addresses configured ON devices. Setup IP address reservations for devices ON the Orbi router.
    Disable any parental controls on the Orbi system.
    Clear out old file share configurations then setup new shares then try to map to them.
    Try mapping to \\IPaddressOfDevice\filesharename
