L58's avatar
L58
Unable to send out gmails
I have set up my RBR50 mesh wifi with 1 satellite. When using the Orbi wifi network all my gmail outgoing messages from my iphone (model XS) do not go through. If I change to another Wifi network everything works. Instead Emails going out from the gmail account from the iMac using Orbi wifi network seems to have no problems.
I have tried to reset account on the iPhone, change the smtp.gmail.com ...but nothing  worked.
Help will be appreciate as I do not know what to do.
Thanks
L
  • FURRYe38's avatar
    Is Armor, Circle, or IPv6 enabled on the RBR?
    • L58's avatar
      L58
      The firmware for the router and the satellite are : V2.5.1.16
      The internet provider is Post Luxemboug ( the state telephone Co)
      The Modem model is the Fritz Box 7490 - this is the standard modem that come with the installation of the internet
      Armor, Circle or IPv6 is not enable on the RBR
      Thanks for any help
      Luigi
