Ulairi
Jun 01, 2018Luminary
Update - Speed Throttling appears fixed by 2nd Reset
I previously had problems with speed being throttled by the Orbi RBR50 router. Router was throttling the speed from 200 Mbps to between 39-100 Mbps with most speeds at about 75. Background info per this thread.
A factory reset restored the speed to normal but the throttling re-occurred after approx 1 week. However, after a second factory reset, I've now been at full speed for 4 weeks so - fingers crossed - it looks to be fixed. If anyone has speed problems and you've exhausted all obvious steps, then try a factory reset.
However, my other problem with the RBW30 wall plug satellite continues (per this thread). Netgear have RMA'd the RBW30 and the replacement is also doing the same thing (causing disconnects and only connecting via 2.4GHz backhaul, even in the same room). Netgear support continues over that issue ...
- UlairiLuminary
6 weeks up and still maintaining normal speeds after the second factory reset. All good.
However, I am noticing something that might give a hint to these sort of problems. Our home network will not be exercising full capacity of 200Mbps down. Typically a maximum of two video strteams (one of which is SD) at any given time.
When I do regular (daily) speed tests, the results are now returning the maximum result (200Mbps down). However, a speed test after a lull preriod of no testing (typically 4-5 days) results in the initial test returning lower values. Tonight after five days of not testing it was 80% on the initial run (160Mbps). However a second, immediate, test gets expected results with maximum pland speeds.
It's almost like the Orbi Router is loosing some setting gradually over time and if I don't frequently exercise it to full capacity (via a speed test) then it 'forgets'. Just a hunch based on results, to-date, over the last 6 weeks. Thoughts?
