sank22
Jan 04, 2018Follower
Update orbi?
I just received this unit, should I not run the firmware update for it? It seems to be running great out of the box! There are a lot of threads for issues so im not sure what has been resolved and what hasnt. I did see there was a beta that was just released too. Any info would be appreciated, thanks.
RBK30(RBR40)
1 Reply
- DarrenMSr. NETGEAR Moderator
If the unit is running fine for you I wouldn't worry about the updates plus orbi updates automatically.
DarrenM
