PhysicalEd
Jul 12, 2017Star
Updated to V1.12.0.18, now Satellite will not sync, "Wireless AP: Off"
I just updated to V1.12.0.18, and now my Satellite will not sync. Everything was working fine on the previous version. I have power cycled both the router and satellite. Following this sugges...
albedo
Jul 16, 2017Guide
Same issue here - regarding reverting firmware, won't the auto-update render that a temporary workaround at best?
Update: indeed, after reverting firmware my RBR40 auto-updates within 15 minutes. At this point the only way I can get my RBS40 to sync is to force a factory reset. It then syncs until either RBR40 or RBS40 are rebooted. Have three days in my return window, am strongly considering going with a different system.
- albedoAug 14, 2017Guide
Still experiencing the same behavior with V1.12.0.20.
- crimsonheadAug 17, 2017Guide
Just an update for all the folks that are following this thread. I have RMA my Router and two Satellites to Netgear. Hopefully, they are able to isolate the issue down and provide necessary fix in the next release.
- ppilot212Aug 17, 2017Star
They aren't going to find anything as the issue has more to do with the crapshoot that is the Orbi Firmware. I RMA'd my Router and Satellite and they still had the same issue.
