PhysicalEd
Jul 12, 2017Star
Updated to V1.12.0.18, now Satellite will not sync, "Wireless AP: Off"
I just updated to V1.12.0.18, and now my Satellite will not sync. Everything was working fine on the previous version. I have power cycled both the router and satellite. Following this sugges...
BenOrbi
Jul 18, 2017Initiate
Me too. Same behavior as others have noted -- Satellite shows up as a Connected Device instead of a Connected Satellite. Logging into at that IP address shows the WiFi radios are off, and no devices are connected to the satellite. Devices connected to the ethernet ports of the satellite also don't work. Downgrading just the Satellite to 1.11.0.20 fixed it, but was quickly broken again by auto update.
JMU1998
Aug 09, 2017Luminary
BenOrbi I can also like others reproduce this bug on demand, factory re-set of satellite helps but it randomly comes back at no particular time interval can be weeks or daysalso sudden power outages during storms will again require factory reset...like others waiting on next Firmware and it's delightful surprises!
