Ra2313
Mar 16, 2024Aspirant
Upgrade router with Orbi RBR40
My existing modem is a C6220 (AC1200). I have an Orbi RBR40 and 2 satellites. My modem is not rated high enough for my internet service so I want to upgrade to CM700. My Orbi is not supported by Netgear any longer. My thought is to save replacing my Mesh system is to get a new router and place that between my modem and the Mesh.
Will the Mesh still be able to use the satellites? Will the system work? I am trying not to but a new Mesh
What speeds are you paying for and who's your isp?
It might be just worth upgrading the modem and keeping the orbi if its meeting your needs.
- Ra2313Aspirant
Xfinity 1200 down.
I also worry about security even though I do have Armor. I definitely want to have a router that will have firmware updates
Thanks
the cm700 doesn't support multigig on xfinity.
I'd look at getting one of the next gen devices that xfinity supports for your modem.
knowledgebase/next-generation-internet - Comcast_Xfinity (reddit.com)
