schmattieboi's avatar
Aug 06, 2020
Upgrading ISP branded (Verizon) Orbi RBR50 and Orbi RBS50 to new firmware
I recently was given an Orbi RBR50 and RBS50 satellite from family as they upgraded to something else. This was great for me as these are way better than what I had before. Naturally, I wanted to make sure the firmware was up to date as I wasn't sure if they were keeping up with that. Currently, the firmware version is showing up as V2.1.4.16_1.0.0.11 . It seems like I had to manually update the firmware to a newer version so I attempted to update to V2.2.1.212; however, was met with this error: "This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product." After some googling, it seems like there is a common issue with updating ISP branded Orbi routers with no easily definitive answers (that I could find). Is anyone aware of a surefire way of updating an ISP branded Orbi router to new firmware?
  • CrimpOn's avatar
    CrimpOn
    How did you conclude that this Orbi was supplied by Verizon?
    (Something on the product label?  Previous owner comments?)
    There is no problem with manually loading the same firmware as is already on an Orbi.
    You might try to manually install v2.1.4.16 and see if it gives the same error.
      • CrimpOn's avatar
        CrimpOn
        Well, (duh) that pretty much takes care of that question.  Thanks.
        One customer got satisfaction from Verizon, although his solution may not apply in your specific case:
        https://community.netgear.com/t5/Orbi/Verizon-FIOS-sold-Orbi-firmware-replacement/m-p/1772268
        On balance, my guess is that you are "stuck".  We have a mantra here, "If it ain't broke, please don't try to fix it."
        So, if the Verizon firmware works as well as you need, maybe better to give up on the issue.
        There is a Chinese hacker who found a way to turn an Orbi router into a satellite.  Maybe (just maybe) that technique could be used to convert it from a Verizon firmware to Netgear firmware.  But, that's a pretty big gamble when the family wants the "internet to work."
  • Just to follow up from when I made this post, I never did attempt to change the firmware from the Verizon stamped one. I just decided to go with an “if it ain’t broke, don’t fix it” approach and my Orbi is still chugging along. If I ever do change routers I may attempt it; but, until then I’ll be sticking to what’s working :) .
