Wim_Merlijn's avatar
Jan 24, 2022
Use RBR50 as a satelite
Hi,
I do have a RBK50 (with RBR50 and RBS50) and want to extend with a RBS50.
But can't purchase new RBS50.
So I a thinking of buying Wifi 6 router (RBK852) and use the RBR50 as a satelite of the RBR850)
Is that supported, will it work?
Thanks in advance for your reply.
Wim
  • plemans's avatar
    Jan 24, 2022
    Not as a satellite. you can hardwire it in and set it up as its own access point
  • plemans's avatar
    With the RBR50 system, there's several satellites you can use.
    RBS20
    RBW30
    RBS40
    RBS40V
    RBS50
    RBS50Y
    • Wim_Merlijn's avatar
      Wim_Merlijn
      Tutor
      Thanks for your quick reply.
      But is it also possible to use the RBR50 as a satelite of a new Netgear Orbi router?
      • plemans's avatar
