u7mg0's avatar
u7mg0
Follower
Nov 28, 2018
Using existing network name
trying to understand the set up.  i plug the Orbi main unit to my existing cable modem with an ethernet cable.  i then want to use my existing network name and password so i don't have to reprogram all my devices (Alexa, TV, netflix, etc)  so i would login to orbilogin.com and change the SSID name and PW to the current one?  will my devices access the satelites now ? and how do they know to go to the sattelites instead of exising modem with weak signal.  thanks, and please no technical acronyms please.
  • Of course you can use same SSID name and PW as before.
  • Disabling the wireless on the ISP router, and ideally re-configure the ISP router to become a pure bridge so the Orbi router can do the NAT and routing - permitting there is no IPTV and VoIP in the play.
