NorbM's avatar
NorbM
Using Orbi as a Bluetooth extender
It would be great to be able to use the Orbi built in Bluetooth radios to extend bluetooth reach throughout a home.
  • What built-in Bluetooth radios?  I'm not aware of any.
    Besides that, Bluetooth is quite necessarily point-to-point, from a security perspective.
    Rodney
  • The Orbi has a Bluetooth Radio. If you can use those radios as Bluetooth extenders it would help with home automation devices (they just need to be close to an orbi pod.
    • rhester72's avatar
      rhester72
      Virtuoso
      If you're referring to the SmallNetBuilder teardown, they were wrong.  Yes, it's on the SoC, but not enabled, and you certainly can't use it with a phone app (or anything else) for setup...that's done entirely via web UI.
      Even if you could somehow enable the radio, you *still* can't extend with it.
      Rodney
