CmdrBond
Jul 21, 2020Aspirant
Virgin Media Hub 3.0 VMDG505/TG2492LG-VM and Orbi RBK50 - HELP!
I am trying to set up a new Orbi RBR50 onto my Hub 3.0 and I cannot get it to detect the internet.
1. I believe my Hub is successfully in modem mode as the light is solid magenta/red/whatever
2. Directly connecting port #4 (lowest) to my laptop gives my laptop internet.
2a. Doing an IPCONFIG /ALL shows the Ethernet adapter as follows:
Connection-specific DNS Suffix : cable.virginmedia.net
DHCP Enabled : Yes
IPv4 Address : 82.xxx.xxx.201 (redacted)
Default Gateway : 82.xxx.xxx.1 (redacted)
DHCP Server : 62.xxx.xxx.xxc (redacted)
DNS Servers : 194.168.4.100 and 194.168.8.100
So all seems well.
But take the lead out of the laptop and plug it into the WAN port on the Orbi, and the Orbi refuses to see the internet connection. (Laptop directly connected to Ethernet port on orbi)
Connecting via DHCP
DHCP Enabled : Yes
So all seems well.
Connecting via DHCP
- CmdrBondAspirantForgot to mention I previously had an RBR40 connected to an original super hub, but something fried the pair of them. The RBR40 won't even turn light up, it just clicks a bit. So I can't test it with that (which was working fine until it died).
CmdrBond wrote:
1. I believe my Hub is successfully in modem mode as the light is solid magenta/red/whatever"I believe" isn't exactly reassuring.
Are you convinced that you are in modem mode.
I'm not sure that I follow the narrative here. Take this bit:
CmdrBond wrote:
But take the lead out of the laptop and plug it into the WAN port on the Orbi, and the Orbi refuses to see the internet connection. (Laptop directly connected to Ethernet port on orbi)Do you mean that simply by plugging the laptop into the Orbi kills the Internet for everything?
I am having a bit of trouble working out what is plugged in where in this scenario.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
DHCP Enabled : Yes
So all seems well.
Connecting via DHCP
