ssandheinrich
Dec 30, 2018Aspirant
VLAN configuration for wireless
I purchased the RBR50 tri-band mesh router for our home from Costco. I noticed that you can only set up one guest network. I was looking into other options to secure my network and isolate traffic....
ssandheinrich
Jan 23, 2019Aspirant
Sorry...I need to re-phrase that. I would like to configure a VLAN so I can have "guests" connect to it rather than use the one built-in guest network. Can I configure that via MAC addresses for wired and wireless clients? I have IOT devices and a renter in my home that I would like to have separate VLANs for. The built-in guest network can be for the infrequent visitors who need internet.
(Had the wrong model listed in the original post. Oops!)
Jan 23, 2019Guru - Experienced User
I don't think it's supported in this kind of configuration.
https://community.netgear.com/t5/Orbi/VLAN-Tagging-for-Guest-Network/m-p/1309248#M9017
I would make contact with NG support and ask them about this to see if it's supported.
- Blanca_OJan 30, 2019NETGEAR Employee Retired
Orbi supports VLAN tagging for ISP. You can check this feature by going into Advanced Setup and it's listed as VLAN/Bridge Settings.
With the kind of configuration you're looking into, this is not supported. You may post your query or suggestion to this page :https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Blanca
Community Team
