sdct989
Jun 23, 2017Tutor
VLAN Tagging for Guest Network
I've seen a couple of posts about this in the past on this forum, but all of them appear to be kinda old, and before you could uncheck the "Allow Guests to see each other and access my local network"...
sdct989
Jun 23, 2017Tutor
peteytesting, thanks for the reply!
I get what you're saying about routing functions belonging to the router, but only the wireless AP knows which network/SSID the traffic came from. So it would be the only one that could augment the traffic in any way to let the router know that this traffic came from this SSID and that traffic came from that SSID. This is typically done in the form of VLAN tagging.
The way that I figured it would work, is that the AP would tag the VLAN that the traffic came from before it passes it off to the router. Forcing the VLAN tags at the AP level also has the added benefit that the client, assuming it's capable of tagging, can't just make up it's own and decide which network it wants to be a part of. It's with these VLAN tags that I can have my router do more advanced routing such as allowing certain requests through the firewall, assigning different dhcp realms, etc.
If you can suggest a different way other than VLAN tags though from my upstream router to understand which SSID a set of traffic came in on though, I could probably also work with that as well!
rhester72
Jun 23, 2017Virtuoso
There's roughly zero chance the Orbi will ever support tagging - it's just not that sophisticated (by design), intended as a "fire and forget" consumer device only.
Rodney
