TonyTiger's avatar
TonyTiger
VLAN/Bridge Settings - Ports on Router or Satelite?
Hello,
When you select VLAN/Bridge Settings and choose ports, is this ports on your router or on your satelite?
BR Tony
  • Ralph0,
    You're welcome! :)  If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    Cheers,
    DaneA
    NETGEAR Community Team
