beshoe25
Mar 10, 2018Initiate
Vulnerability Catalogue ID CVE-2017-14491
AVAST Network Scan shows this Vulnerability ID
I have the latest firmware on both satillites and router by this persistes, any idea how to fix this issue? Is there a setting in the router that I can change? Or am I at the mercey of Netgear to make a new firmware update?
Unknown
The device is vulnerable to hacker attacks. For more info see the corresponding vulnerability ID. An upgrade of the device's software/firmware may fix the issue.
Vulnerability ID:
IP Address:
- britonAspirant
Model WNR3500Lv2
This problem still persists 3/29/2018. No firmware update is available for this model.
Have you been in conact with NG support about this? Might see if there is any more information on this or ask about using a Beta FW.
beshoe25wrote:AVAST Network Scan shows this Vulnerability ID
Unknown
Vulnerability ID:
IP Address:
- bobwilleyAspirant
Looking for an answer to this, AVAST has pointed to an issue.
I was running on an iMac 27" 2017 Retina5K 24Gb 1TB 3.4Ghz Intel Core i5, macOS High Sierra 10.13.4
RBR40 Route with 2 satellites
Hardware Version RBR40 Firmware Version V2.1.2.18 GUI Language Version V1.0.0.314 - FURRYe38Guru - Experienced User
See if v2.1.3.6 is available for the RBR or RBK40. If it is, try upgrading FW. Reset then setup from scratch and test.
If not, you should contact NG support and ask for help and information on this.
bobwilley wrote:Looking for an answer to this, AVAST has pointed to an issue.
Hardware Version RBR40 Firmware Version V2.1.2.18 GUI Language Version V1.0.0.314 - bobwilleyAspirant
Model Name Device Name Current Version Status Router RBR40 RBR40 V2.1.2.18 No new firmware version available. Satellite RBS40 Orbi Satellite-1 V2.1.2.18 No new firmware version available. Satellite RBS40 Orbi Satellite-2 V2.1.2.18 No new firmware version available.
