DaddyMan
Oct 15, 2018Aspirant
Want to use Orbi RBK53 as primary router and mesh with Airport Extreme as extender
I am replacing my Apple Airport Extreme Base station router with Orbi RBK53 and want to re-purpose my Airport Extreme (AE) as an extender/beacon (in bridge mode) but without using any ethernet cables from the AE. I am fine if the AE needs to be plugged in to the Orbi for the time I need to go through the factory reset and re-setup as a bridge, but operationally I would like to have the AE setup as a bridge/extender/beacon in my basement (well within signal range of the router RBR50).
Can anyone confirm this is do-able? Existing answers I have read on this forum all say that the have cables running to the router or a switch connected to the router - this unfortunately is not an option for me!
You can use AE in wireless bridge mode if it supports it. It should connect to the 5ghz radio on the orbi as a connected client.
You'll have to try this out and see. You'll need to refer to Apples support site and information on configuration of the AE...
- AC641Luminary
Is using a couple of Powerline Adapters an option to give you the Ethernet connection?
- DaddyManAspirant
I would still have the issue of running cables from the adapter to the Airport Extreme (AE) Basestation as extender/bridge. It's an impractical option but slightly better than running Ethernet cables end-to-end through walls & floors...
- DaddyManAspirant
FURRYe38 - will have to try that - so far it seems experimentation is the way to go forward - will be an undertaking and sharing on this forum - any thoughts on how do I ensure testing if the AE is functioning as desired?
- ekhalilMaster
DaddyMan wrote:
will have to try that - so far it seems experimentation is the way to go forward - will be an undertaking and sharing on this forum - any thoughts on how do I ensure testing if the AE is functioning as desired?I tried to connect my Airport Time Capsule wirelessly to Orbi but that did not work for me! I did not get the option "Extend Cusrrent Network" that you usually get if the network is from another Airport router.
- DaddyManAspirant
ekhalil - that is precisely what I am unable to do - connect using cables
ekhalil wrote:
